"Error listing directory" when opening a folder with many files in S3
roland
Donor+
Munich
Version: 6.3.3, GUI
Protocol: S3
When opening a folder with many files (in this case: 18.000 but happens already with less) the files get loaded obviously alright, but with a modal with the message "error listing directory...file or folder does not exist" (see screenshot).
When clicking OK you can continue working but the error will happen again on every refresh of the folder.
I've checked the "common error messages", where it says this could happen due to a server timeout. I tried to change the setting from 15 to 30 seconds, but the error persists (and comes just after a few seconds, not anything close to 15 or 30 seconds).
Re: "Error listing directory" when opening a folder with many files in S3
roland
Donor+
Munich
Logfile
OK, here is the logfile. I've set it to private though, as it contains potentially sensitive URLs and filenames.
  • winscp-log.log (6.02 MB, Private file)
Re: Logfile
Thanks. You seem to be connecting to some proprietary server using S3 protocol.
The server pages the directory contents by 1000 objects/files.
The directory contains exactly 18000 files, so exactly 18 pages.
With the actual Amazon S3 server, the last (18th) page would say:
<IsTruncated>false</IsTruncated>
while your server says:
<IsTruncated>true</IsTruncated>
So WinSCP reads one more "page".
The server returns an empty page.
That's another difference to the actual Amazon S3 server, which never returns an empty page, unless you are asking for listing of directory/prefix that actually does not exist. WinSCP gets confused here by these two differences and hence the "File or folder ... does not exist" error.
I can improve WinSCP not to error, if it gets an empty page, unless it is the first page.
But I'm not sure how your server responds to an actual empty directory/prefix. Can you send a log for that?
roland
Donor+
Munich
Logfile again
Sorry for not getting back to you earlier, but here it comes. The logfile shows WinSCP opening an empty folder called Sonstiges. Hope that is what you need. I set the logfile to private as last time.
  • winscp-log.log (25.47 KB, Private file)
