trouble removing .filepart for larger files
sthomp87@gmail.com
Hello – bear with me I am a novice.
Sending sftp .csv files and the other party is reporting that they are unable to integrate the files when .filepart is appended to the files.
I've followed the below directions:
To avoid encountering the ".filepart" issue in WinSCP, you can disable the filepart setting. Follow these steps:
Open WinSCP and navigate to 'Options.'
In the 'Preferences' menu, go to 'Transfer'.
Click on 'Endurance'.
Under 'Enable transfer resume/transfer to temporary filename for', select 'Disable'.
Click 'OK' to save the changes.
However, files over 100KB are still showing with the appended extension. Am I missing a step?
Re: trouble removing .filepart for larger files
The instructions are correct. Please double check that the settings were saved.
Are you uploading with GUI, right? Aren't you using scripting?
