Batch file to synchronize a folder without a password
briandent
I have a batch file that synchronizes a folder to another location using TLS/SSL Explicit encryption. I have the credentials stored in the .bat file and I have a session setup in the GUI. But for security I'd like to use the session rather than the command line including the credentials. I've been through the doc but I'm just not seeing how to do this. Is it possible to pull the session info from the GUI?
This is from the batch file with some of the lines truncated for readability:
  /log="%~dp0%~n0_winscp.log" /ini=nul ^
  /command ^
    "open ftpes://admin:password@x.y.com/ -certificate=""9a:..."" -rawsettings ProxyPort=1" ^
    "lcd E:\BERYL\BACKUPS" ^
    "cd /BACKUPS" ^
    "put -filemask=""*.log>1D;*.7z>1D"" -neweronly  *" ^
    "exit" >> %~dp0%~n0.log
