VBA example won't work
Marrob
Italy
It looks as if the sessionOptions class is empty?!?!
the WITH fails:
The class does not support the expected interface
area
+ : provaFTP : : provaFTP/provaFTP
- : mySession : : Session/Session
- : mySessionOptions : : SessionOptions/SessionOptions
: : <Nessuna variabile> :
: myTransferOptions : Nothing : TransferOptions
: transferResult : Nothing : TransferOperationResult
: transfer : Nothing : TransferEventArgs
code:
Private Sub Upload(ByRef mySession As Session)
    ' Imposta le opzioni di sessione
    Dim mySessionOptions As SessionOptions
    Set mySessionOptions = New SessionOptions
    With mySessionOptions
    .Protocol = "Protocol.Sftp"
    .HostName =
Marrob
Italy
Re: VBA example won't work
Thanks a lot, but without " as in the example I have a
Compilation error : impossibile trovare il metodo o il membro dei dati
Do you have working examples?
When do you inspect the SessionOption object what do you see?
Regards
All the examples on our site are working.
I've even tested your code. After the above correction, it is WORKING in Excel.
How exactly are you using/running the VBA code? Post some screenshots.
