Forcing batch command window closed
mas985
California
I am running WinSCP in a windows batch file and I was wondering if it is safe to force the command window closed before WinSCP completes the tasks. Will WinSCP end gracefully and not fragment a partially downloaded file?
mas985
California
I don't think you understood my question.
I know that the underlying process stops when the windows command window closes. However, what I want to know is exactly how WinSCP closes. When a command window is forced closed, Windows sends the application a close command but how does WinSCP respond to that command while in the middle of transferring a file? Does WinSCP close gracefully so that no files in the process of being downloaded are corrupted?
mas985
California
I experimented with this and confirmed that a fragment was left behind and was dated with the current time. I re-ran the script and it seems to download the file again with the correct modified date which is a good thing so at least it corrects the file after the fact.
There are times where I run a long script and for one reason or another, need to cancel it and run it at a different time so I was just curious as to what might happen.
Thanks for your help!
