ESXi 8.0 U3 SCP Failure
useratx
Hello. I'm trying to download a file from an ESXi 8.0 U3 server, to a Windows client running Windows 10 22H2. Alternatively, I was able to use the native scp within ESXi to copy the file to a Linux host without any issues.
. 2025-01-13 09:29:11.652 Copying 1 files/directories to local directory "C:\Users\username\Downloads\" - total size: 157,661,184
. 2025-01-13 09:29:11.652   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2025-01-13 09:29:11.652   TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; EncryptNewFiles: Yes; ExcludeHiddenFiles: No; ExcludeEmptyDirectories: No; InclM: ; ResumeL: 0
. 2025-01-13 09:29:11.652   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
> 2025-01-13 09:29:11.652 echo "WinSCP: this is begin-of-file" ; scp -r -p -d -f "win.iso" ; echo "WinSCP: this is end-of-file:$?"
< 2025-01-13 09:29:11.654 WinSCP: this is begin-of-file
. 2025-01-13 09:29:11.654 Sending NULL.
< 2025-01-13 09:29:11.657 T1736781874 0 1736781881 0
. 2025-01-13 09:29:11.657 Sending NULL.
< 2025-01-13 09:29:11.658 C0644 157661184 win.iso
. 2025-01-13 09:29:11.659 File: '/tmp/win.iso' [2025-01-13T15:24:34.000Z] [157661184]
. 2025-01-13 09:29:11.661 Asking user:
. 2025-01-13 09:29:11.661 **Overwrite local file 'win.iso'?**
. 2025-01-13 09:29:11.661 Destination directory already contains file 'win.iso'.
. 2025-01-13 09:29:11.661 Choose, if you want to overwrite the file or skip this transfer and keep existing file.
. 2025-01-13 09:29:11.661 New:         157,661,184 bytes, 2025-01-13 9:24:34 AM
. 2025-01-13 09:29:11.661 Existing:    98,402,304 bytes, 2025-01-13 9:24:41 AM ()
. 2025-01-13 09:29:12.705 Answer: Yes
. 2025-01-13 09:29:12.713 Sending NULL.
. 2025-01-13 09:29:12.713 Binary transfer mode selected.
. 2025-01-13 09:29:15.856 Session exited on unrecognised signal "PIPE"
. 2025-01-13 09:29:15.908 Main session channel closed
. 2025-01-13 09:29:15.909 All channels closed
. 2025-01-13 09:29:15.909 Attempt to close connection due to fatal exception:
* 2025-01-13 09:29:15.909 **Connection has been unexpectedly closed.** Server sent command exit status 128.
. 2025-01-13 09:29:15.909 Closing connection.
* 2025-01-13 09:29:16.344 (ESshFatal) **Connection has been unexpectedly closed.** Server sent command exit status 128.
* 2025-01-13 09:29:16.344 Copying file 'win.iso' fatally failed.
* 2025-01-13 09:29:16.344 Copying files from remote side failed.
useratx
SFTP did work. The issue is fixed now. The root cause was due to a VxRail bug that didn't clean up SSH sessions, causing an out of memory error on the ESXi hosts.
Kareem
Esxi 7.0 upload failed
How can I overcome this problem specially it's mandatory to use scp file type and there's no option to append or resume and if I use sftp instead of scp?
Re: Esxi 7.0 upload failed
@Kareem: I'm not sure I understand the question. Do you mean that you cannot use SFTP protocol and have to use SCP? Why? Please post session log file showing the problem. Can you download any file at all? Or do you have problems with some specific files only?
