-nopermissions switch -nopreservetime unknown
GF GANZERLA
I have a scripted automatic file transfer, but the destination server reports the error
Upload of file .. was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn off setting permissions or preserving timestamp . Alternatively you can turn on 'Ignore permission errors' option.
I tried adding -nopermissions and -nopreservetime switches, but it doesn't work.
Unknown switches.
Here is the open command executed in the script:
"open Sarmog-MC-AWS -passphrase="mypassword" -nopermissions -nopreservetime"
Re: -nopermissions switch -nopreservetime unknown
Those are switches of the put command, not open.
https://winscp.net/eng/docs/scriptcommand_put#nopreservetime
See Upload of file .. was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on ‘Ignore permission errors’ option.
