Windows 11 PC, no Window opens
nolatron
Hi all,
Having an issue starting WinSCP in Windows 11 24H2 with a single monitor. Downloaded and installed WinSCP 6.3 today.
After starting from the desktop shortcut, nothing happens. Task manager shows a process running but there's no taskbar icon or window open. I tried all the suggested steps here, https://winscp.net/eng/docs/faq_no_window, but it made no difference.
No errors in Event viewer either.
Any suggestions?
Thanks.
Re: Windows 11 PC, no Window opens
Your Windows Documents folder path is misconfigured as C:\Users\username\\Documents. I've fixed WinSCP to be able to cope with that:
Issue 2330 – Hang when opening path with duplicated backslash
But you might want to fix your Windows configuration anyway, as it might bite you elsewhere later.
I'm sending you an email with a development version of WinSCP.
