S3 connection
snijcom
S3 connection
After making a connection to an S3 account, I can't see the bucketnames.
I have already tried the option in remote directory: /bucketname but then the login is refused.
Re: S3 connection
Also post a verbose log from any other S3 client (e.g. commandline aws) showing how it can list the buckets using the same credentials from the same local machine.
S3 connection
Found another solution for this problem : mountainduck.
It even mounts the bucket with a drive mapping to a letter so you can even use it in the explorer of windows and copy files to this drive letter.
