Changing Remote directory problem...
Jeff
Great Program.
With 2.0 ver 106 there is a small bug that happens when you schange the remote directory that is the parent of the site root from the pull-down. The program exits and returns this error:
Assertion failed: State !=rsUndef, file
RemoteFiles.cpp line 724.
Thanks for your work!
Re: Changing Remote directory problem...
Do you mean that you are e.g. in directory "/aaa/bbb/ccc" and from terminal you rename directory "bbb" to "ddd"?
Jeff
If I am in a directory such as /home/sites/site1/web and use the pull down to switch to a directory that the user does not have rights to like /home/sites/ then the error comes up.
This works for me. Can you write me, what are the rights in inaccessible directory set to (exactly)? Log file would be fine too (via e-mail).
Jeff
I just installed the new version (110) and it does not have the same problem as I described.
