Network error: Software caused connection abort
supawist
Hi everyone, I'd like some support on this.
I've been using this credential for WinSCP for quite some time.
After a while that I didn't connect to WinSCP, a strange behavior would occur
  • I can authenticate with same password as usual
  • WinSCP seem to show the files in remote folder
  • When clicking into some files in folder, an error would say
    which caused me to reconnect again. And repeat...
Any solutions would help since I've got stuck for almost a month here. Thank you!
Re: Network error: Software caused connection abort
Can you access those files using any other client using the same protocol?
