Type 11 Disconnect when trying to use GetFileToDirectory
icoryx
I'm trying to download a file from an SFTP Server to a local fileserver using the GetFileToDirectory method. I am using the DLL Version 6.3.5.0 in PowerShell to do that.
Here's the basic script that I am using:
$winSCPPath = "D:\Path\To\DLL"
Add-Type -Path $winSCPPath
[string]$script:sftpServer = "xxxxx"
[string]$script:username = "xxxxx"
[string]$script:password = "xxxxx"
[string]$script:fingerprint = "xxxxx"
[int]$script:port = xxxxx
$securePassword = ConvertTo-SecureString -String $password -AsPlainText -Force
$scplogpath = "$PSScriptRootFix\logs\script.log"
$remotePath = "/Path/To/Remote/File.msi"
$localPath = "\\fileserver\Place\File\Here\"
        HostName = $sftpServer
        UserName = $username
        SecurePassword = $securePassword
        SshHostKeyFingerprint = $fingerprint
        PortNumber = $port
$session.SessionLogPath = $logpath
$session.GetFileToDirectory($remotePath, $localPath, $false, $null)
When I try to run just this it sometimes works and sometimes it doesn't. In the full script it never works. This is the error that I receive:
Remote side sent disconnect message
type 11 (by application):
"FlowSshPacketDecoder: unresponsiveness timeout"
Can't get attributes of file '/Path/To/Remote/File.msi'.
Is it just an issue with timeout? Or maybe the full version of my script somehow crashes the session? All it does is create 2 hashtables with remote/local files, compares them and then tries to download the missing files using the method above...
Description: I've removed personal data the rest is untouched.
Re: Type 11 Disconnect when trying to use GetFileToDirectory
The log does not match your code. The log shows that Session.ListDirectory or similar was called after the session was opened. Then there was a 5 minutes pause before the download. During the pause the server somehow timeouted (although the connection was kept alive).
icoryx
Thanks for the reply!
The log might not be matching because I stripped the script down by a lot. The full script has a lot of stuff that should be irrelevant to the issue but here it is:
#Make PSScriptRoot available in psISE
$PSScriptRootFix = $MyInvocation.MyCommand.Path | Split-Path -Parent
#Load WinSCP .NET assembly
$winSCPPath = if ($env:WINSCP_PATH) { $env:WINSCP_PATH } else { "$PSScriptRootFix\WinSCPNETAssembly" }
$tempSCPPath = "C:\temp\WinSCPNETAssembly"
$tempAssemblyPath = (Join-Path $tempSCPPath "WinSCPnet.dll")
Copy-Item -Path $winSCPPath -Destination $tempSCPPath -Recurse -Force
Add-Type -Path $tempAssemblyPath
[string]$script:sftpServer = "***.***.***.***"
[string]$script:username = "******"
[string]$script:password = "******"
[string]$script:fingerprint = "******"
[int]$script:port = 65535
#region Functions
function Write-ConsoleLog {
    param (
        [string]$message,
        [System.ConsoleColor]$foregroundColor = "White",
        [switch]$noNewLine
    $params = @{}
    if ($noTime -eq 1) {
        $params["Object"] = "$message"
        $params["ForegroundColor"] = $foregroundColor
        $script:noTime = 0
    } else {
        $params["Object"] = "$(Get-Date -Format 'yyyy-MM-ddThh:mm:ss') $message"
    if ($noNewLine) {
        $params["NoNewLine"] = $true
        $script:noTime = 1
    Write-Host @params
function New-WinSCPSession {
    [CmdletBinding()]
    param (
        [Parameter(Mandatory)]
        [string]$sftpServer,
        [string]$username,
        [string]$password = "",
        [string]$fingerprint,
        [int]$port,
        [string]$logpath = ""
    begin {
        #PSCredential
        #SFTP SessionParameters
        if ($port) {
                PortNumber = $port
        else {
                Hostname = $sftpServer
                Username = $username
    process {
    end {
        return $session
function Get-SFTPFiles {
    [CmdletBinding()]
    param (
        [WinSCP.Session]$SCPsession,
        [string]$remotePath
    begin {
        #Hashtable for the remote files
        $remoteFilesHashTable = @{}
    process {
        Write-ConsoleLog "Getting SFTP Child-Item $remotePath" Cyan
        $remoteFiles = $script:SCPsession.EnumerateRemoteFiles($remotePath, $null, [WinSCP.EnumerationOptions]::AllDirectories)
        Write-ConsoleLog "Populating Hashtable... " Cyan -NoNewline
        $filecounter = 1
        foreach ($file in $remoteFiles) {
            $remoteFilesHashTable["file_$filecounter"] = [PSCustomObject]@{
                Name = $file.Name
                Path = $file.FullName
                Size = $file.Length
                LastWriteTime = $file.LastWriteTime
                Quartal = ""
            $filecounter += 1
        Write-ConsoleLog "Done" Green
    end {
        return $remoteFilesHashTable
function Get-LocalFiles {
    [CmdletBinding()]
    param (
        $localPath
    begin {
        #Hashtable for local Files
        $localFilesHashTable = @{}
    process {
        Write-ConsoleLog "Getting Local Child-Item $localpath ... " Cyan -NoNewline
        $localPath = $localPath.trimstart("\\")
        $localFiles = Get-ChildItem -Path "\\?\UNC\$localPath" -Recurse | Where-Object { -not $_.PSIsContainer }
        $filecounter = 1
        foreach ($file in $localFiles) {
            $localFilesHashTable["file_$filecounter"] = [PSCustomObject]@{
                Name = $file.Name
                Size = $file.Length
                Quartal = ""
            $filecounter += 1
    end {
        return $localFilesHashTable
#endregion
#region Main
#SFTP Session
$SCPsession = New-WinSCPSession -sftpServer $sftpServer -username $username -password $password -fingerprint $fingerprint -port $port -logpath $scplogpath
#Collect Files
$eFiles = Get-SFTPFiles -SCPsession $SCPsession -remotePath "/Downloads/"
$anKFiles = Get-SFTPFiles -SCPsession $SCPsession -remotePath "/anK/"
#Quartale setzen
$eQuartale = @()
foreach ($file in $eFiles.Keys) {
    if ($eFiles[$file].Path -match "/Downloads/[\d]{4}-[1-4]/.*") {
        $remoteQ = ($eFiles[$file].Path -split "/")[4]
        $localQ = $remoteQ -replace "-", ""
        $eFiles[$file].Quartal = $localQ
        if ($eQuartale -notcontains $localQ) {
            $eQuartale += $localQ
$eMissingFiles = @{}
#local files
$noQFolders = Get-LocalFiles -localPath "\\fileserver\noQ\"        #Hashtable für Quartalsunabhängige Dateien
#$gQuartale = Get-ChildItem -Path "\\fileserver\dep\" | where { $_.Name -match "[\d]{4}[1-4]" } | Sort-Object Name  #lokale Quartale
$gQuartale = Get-ChildItem -Path "\\fileserver\dep\" | where { $_.Name -match "2024[1-4]" } | Sort-Object Name     #lokale Quartale nur 2024 (zum Test)
$gQuartalHashtables = @{}
#Get local Q Files
foreach ($q in $eQuartale) {
    if (Test-Path "\\fileserver\dep\$q\G") {
        $gQuartalHashtables = Get-LocalFiles -localPath "\\fileserver\dep\$q\G"
#Get missing/altered files
    Write-Host "$($eFiles[$file].Name)... "-NoNewline
    if (($eFiles[$file].Quartal).length -gt 0) {
        $localQ = $eFiles[$file].Quartal
        if ($gQuartalHashtables.ContainsKey($localQ)) {
            if ($gQuartalHashtables[$localQ].ContainsKey($file)) {
                if ($gQuartalHashtables[$localQ][$file].Size -ne $eFiles[$file].Size -or $gQuartalHashtables[$localQ][$file].LastWriteTime -ne $eFiles[$file].LastWriteTime ) {
                    $eMissingFiles[$file] = $eFiles[$file]
                    Write-Host "found but different attributes"
                else {
                    Write-Host "found"
            else {
                Write-Host "missing"
        else {
            Write-Host "kein Quartal"
    else {
        $eFiles[$file].Quartal = "Quartalsunabhaengig"
        if ($noQGFolders.ContainsKey($file)) {
            if ($noQGFolders[$file].Size -ne $eFiles[$file].Size -or $noQGFolders[$file].LastWriteTime -ne $eFiles[$file].LastWriteTime ) {
            else {
                Write-Host "found"
        else {
#Download missing/altered files
foreach ($file in $eMissingFiles.Keys) {
    $remotepath = $eMissingFiles[$file].Path
    if ($eMissingFiles[$file].Quartal -match "Quartalsunabhaengig") {
        $remotePathRel = $remotepath -replace "/Downloads/noQ",""
        $localpath = Join-Path "\\fileserver\noQ\" $remotePathRel | Split-Path -Parent
    else {
        $remoteQ = "$(($eMissingFiles[$file].Quartal).Substring(0,4))-$(($eMissingFiles[$file].Quartal).Substring(4,1))"
        $remotePathRel = $remotepath -replace "/Downloads/$remoteQ",""
        $localpath = Join-Path "\\fileserver\dep\$($eMissingFiles[$file].Quartal)\G" $remotePathRel | Split-Path -Parent
    Write-ConsoleLog "Downloading $file to $localpath" Cyan
    $SCPsession.GetFileToDirectory($remotepath,$localpath,$false,$null)
$SCPsession.Close()
Remove-Item -Path $tempAssemblyPath
Read-Host "Press Enter to Continue"
Now the log should match with the script. I have only renamed some paths so they might still be off.
icoryx
I guess the issue might be that the time between listing the files, comparing them and downloading them is too long? Is there any way to increase this? Some sort of keepalive option?
