SessionOptions.Timeout set to 120 seconds but connection times out in about 20 seconds
greb
I am using winscp.exe and WinSCPnet.dll 6.3.5.0 and .NET framework 4.6.1.
I set the session option timeout to 120 seconds; however,when calling Session.Open, the session times out after 15–20 seconds. how can I increase the timeout in seconds to the value I've configured?
var sessionOptions = new SessionOptions();
sessionOptions.Protocol = Protocol.Sftp;
sessionOptions.HostName = processArguments.FtpServerName;
sessionOptions.UserName = processArguments.FtpUserName;
sessionOptions.Password = processArguments.FtpPassword;
sessionOptions.Timeout = TimeSpan.FromSeconds(120);
    session.ExecutablePath = executablePath;
    session.Open(sessionOptions);
Re: SessionOptions.Timeout set to 120 seconds but connection times out in about 20 seconds
Generally, a timeout is just a hint to the system. If system decides that it's pointless to wait further, it can give up earlier.
If you want us to check further, please attach a full session log file showing the problem (using the latest version of WinSCP).
