Put with switch "-append"
magowoody
Hi.
I can't use the -append switch connected to the put operator inside a script.
My goal is to add the content of the text file I'm sending when it is already present in the destination server.
I'm using the SFTP protocol with public key access and private key with "passphrase".
This is the relevant part of my .BAT script:
rem Generate temporary script
  echo open sftp://<user>@<url-sftp> -privatekey=%_pathKey%\<file>.ppk -hostkey="<privatekey>" -passphrase="<passphrase>"
  echo lcd <localpath>
  echo cd <remotepath>
  echo put -append -preservetime "<file>" <file>"
  echo put -nopreservetime "<file_fake_last_connection>" "<file_fake_last_connection>"
  echo exit
) > script.tmp
rem Run temporary script
%_path%\winscp.com /ini=nul /log=%_path%\log\<file_log.log> /logsize=5*1M /loglevel=-1 /script=script.tmp
The file is sent correctly but on the server the file is always overwritten.
At the moment I solved it by importing the file from the server and then merging it with the one to be sent on the client side, but I would be interested in understanding how to use the -append switch with the put command as per the documentation https://winscp.net/eng/docs/scriptcommand_put and https://winscp.net/eng/docs/scriptcommand_put#append.
I hope someone can help me.
Max
Re: Put with switch "-append"
magowoody
> 2024-12-27 12:53:09.254 Script: put -append -preservetime "timbacq.dat" "timbacq.dat"
. 2024-12-27 12:53:09.254 Copying 1 files/directories to remote directory "/in" - total size: 840
. 2024-12-27 12:53:09.254 File: 'timbacq.dat' [2024-12-27T09:55:01.919Z] [840]
. 2024-12-27 12:53:09.254 Copying "timbacq.dat" to remote directory started.
. 2024-12-27 12:53:09.318 Preserving timestamp [2024-12-27T09:55:01.000Z]
. 2024-12-27 12:53:09.558 Transfer done: 'timbacq.dat' => '/in/timbacq.dat' [840]
. 2024-12-27 12:53:09.558 Copying finished: Transferred: 840, Elapsed: 0:00:00, CPS: 2.763/s
This is the affected portion of the log.
As you can see I also use the -preservetime parameter which however does not affect the problem.
I tried to remove it leaving only -append but there are no differences.
At the very least, please post log on the Normal logging level.
Not the Reduced level: /loglevel=-1
magowoody
Hi Martin,
This is the portion of the log affected with /loglevel=0
> 2024-12-30 09:25:11.704 Script: put -append -preservetime "timbacq.dat" "timbacq.dat"
. 2024-12-30 09:25:11.704 Copying 1 files/directories to remote directory "/in" - total size: 1.020
. 2024-12-30 09:25:11.704   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask: timbacq.dat
. 2024-12-30 09:25:11.704   TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; EncryptNewFiles: Yes; ExcludeHiddenFiles: No; ExcludeEmptyDirectories: No; InclM: ; ResumeL: 0
. 2024-12-30 09:25:11.704   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2024-12-30 09:25:11.710 File: 'timbacq.dat' [2024-12-27T09:54:41.227Z] [1020]
. 2024-12-30 09:25:11.710 Copying "timbacq.dat" to remote directory started.
. 2024-12-30 09:25:11.710 Binary transfer mode selected.
. 2024-12-30 09:25:11.710 Opening remote file.
I believe it's wrong SFTP implementation on the server. It probably ignores SSH_FXF_EXCL flag, and overwrites the existing target file. Consider contacting the server provider/author. If you want me check further, please post level 2 log.
magowoody
Hi Martin,
I received confirmation that this flag is not currently supported in FileZilla Pro.
It will be added in the next release.
magowoody
Still regarding: Put with switch "-append"
Hi Martin,
I'm referring to this post from early 2025.
In one of the latest releases of FileZilla Server Pro (1.12.14 to be precise), the -append switch that was implemented in version 1.9.5 stopped working.
I wrote to FileZilla technical support explaining the problem, and this was their response:
WinSCP has some very unusual behavior for appending. For unknown reasons it wants to open a file with the combination of SSH_FXF_WRITE|SSH_FXF_CREAT|SSH_FXF_TRUNC|SSH_FXF_EXCL. Combining TRUNC and EXCL makes no sense and this is what confuses FileZilla Pro Enterprise Server.
Besides, why would it try to open the file with SSH_FXF_EXCL to begin with? It cannot be used for appending, one would expect either SSH_FXF_CREAT|SSH_FXF_WRITE|SSH_FXF_APPEND, or alternatively SSH_FXF_CREAT|SSH_FXF_WRITE followed by a SSH_FXF_FSTAT on the returned handle to obtain the append offset.
I currently use WinSCP (6.5.1) to send.
Is it possible to achieve compatibility with the evolution of FileZilla Server Pro based on their support specifications?
Has this mode already been implemented differently in subsequent versions?
I look forward to your kind feedback.
Thank you.
Max
magowoody
Re: Still regarding: Put with switch "-append"
Hi Martin,
I tested the new version.
Now the -append switch is working again.
If the file is found on the server, it is appended correctly.
Since the service where WinSCP is used is in production, can I trust using this development version?
I would still prefer to use an official release version.
When is a new release expected that includes this feature?
You did a great job.
Max
Thanks for you feedback. An official beta release with the change is likely coming soon. But stable release is weeks, maybe months, away. The development version you already have should be stable enough.
