Enter the path directly to the address bar in the commander interface
adamyin
Currently, it supports to enter the path directly to the address bar in the Explorer interface. Could it support the same function in the Commander interface?
Re: Enter the path directly to the address bar in the commander interface
Thanks for your suggestion.
What advantage would it have over using the "Open directory" command?
