Batch File not uploading but GUI works fine
pooky1233
I generated code to upload a folder to a server and when I run the file it outputs an Error.
However when loading the folder in the GUI it has no issue.
What could be the issue
Below is the code
@echo off
  /log="C:\writable\path\to\log\WinSCP.log" /ini=nul ^
  /command ^
    "open sftp://root:PASSWORD@IP/ -hostkey=""ssh-ed25519 255 rGxL7IIE6uBTft67P21537kT2jmxbwRIzM0vV+Zp6Hs""" ^
    "lcd C:\Users\User\Desktop\College" ^
    "cd /root/sync" ^
    "put YearTwo" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error %WINSCP_RESULT%
exit /b %WINSCP_RESULT%
Re: Batch File not uploading but GUI works fine
What error?
A log file of equivalent upload in GUI would be useful too.
