Output file when error
npoinard
sorry if my question has been already asked, I haven't found it.
I've in my SFTP script, an time out error
Error: Network error: Connection to "*******-******.com" timed out.
I would like to have an .txt file when I got this error.
Then I could make a check on the présence of this file.
Thanks in advance
Nicolas.
npoinard
Hello martin,
Initial I've a cmd file:
Cd D:\SFTP
date /t > \\IP-ADRESS\d$\SFTP_Bloomberg_BTCA\SFTP.txt
time /t >> \\IP-ADRESS\d$\SFTP\SFTP.txt
powershell.exe "\\IP-ADRESS\d$\SFTP\sftp.ps1" >> \\IP-ADRESS\d$\SFTP\SFTP.txt
move \\IP-ADRESS\d$\SFTP\PROD\*.csv \\IP-ADRESS\d$\SFTP\PROD\archive\ >> \\IP-ADRESS\d$\SFTP\SFTP.txt
del /f \\IP-ADRESS\d$\SFTP\PROD\*.csv >> \\IP-ADRESS\d$\SFTP\SFTP.txt
date /t >> \\IP-ADRESS\d$\SFTP\SFTP.txt
The PowerShell launched is formatted like that,
try
    # Load WinSCP .NET assembly
    Add-Type -Path "D:\SFTP\WinSCPnet.dll"
    # Setup session options
        HostName = "url"
        UserName = "user"
        SshPrivateKeyPath = "D:\SFTP\private.ppk"
        PrivateKeyPassphrase = "pass"
        GiveUpSecurityAndAcceptAnySshHostKey = "true"
    try
        $session.SessionLogPath = "D:\SFTP\winscp-upload.log"
        # Connect
        # Upload files
        $transferOptions.ResumeSupport.State = [WinSCP.TransferResumeSupportState]::Off
        $transferOptions.FilePermissions = $Null
        $transferOptions.PreserveTimestamp = $False
        $transferResult = $session.PutFiles("D:\SFTP\prod\*.csv", "/", $False, $transferOptions)
        # Throw on any error
        $transferResult.Check()
        # Print results
            Write-Host ("Upload of {0} succeeded" -f $transfer.FileName)
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    Write-Host ("Error: {0}" -f $_.Exception.Message)
    exit 1
I've some instability on the network and get the timeout when I try to connect
It would like that "Error: Network error: Connection to "*******-******.com" timed out. " in a txt file,
I'll user it has flag file to retry the connection if it's failed.
If you need to retry the connection, just loop, when the exception is thrown.
If you insist on your error file hack, just create the file in the catch clause.
catch [Exception]
    Set-Content -Path "error.txt" -Value $_.Exception.Message
    exit 1
