ksrinivasan
if exist rm file not working in batch script
ksrinivasan
Here is the actual solution
@echo off setlocal REM Specify the path to WinSCP executable set WINSCP_PATH="C:\Program Files (x86)\WinSCP\WinSCP.com" REM Specify the path to the WinSCP script file set SCRIPT_PATH="C:\path\to\winscp_script.txt" REM Specify the path for the log file set LOG_PATH="C:\path\to\winscp.log" REM Create a temporary script file set TEMP_SCRIPT="C:\path\to\temp_script.txt" REM Connect to the server and list .csv files echo open sftp://username:password@example.com/ -hostkey="ssh-rsa 2048 xxxxxxxxxxxxxxx..." > %TEMP_SCRIPT% echo cd /remote/directory/path >> %TEMP_SCRIPT% echo ls *.csv >> %TEMP_SCRIPT% echo close >> %TEMP_SCRIPT% echo exit >> %TEMP_SCRIPT% REM Run the temporary script and capture the output %WINSCP_PATH% /script=%TEMP_SCRIPT% /log=%LOG_PATH% /loglevel=2 > output.txt REM Check if any .csv files exist based on the output findstr ".csv" output.txt >nul if %errorlevel%==0 ( REM If .csv files exist, create a script to delete them echo open sftp://username:password@example.com/ -hostkey="ssh-rsa 2048 xxxxxxxxxxxxxxx..." > %SCRIPT_PATH% echo cd /remote/directory/path >> %SCRIPT_PATH% echo rm *.csv >> %SCRIPT_PATH% echo close >> %SCRIPT_PATH% echo exit >> %SCRIPT_PATH% REM Execute the script to delete the files %WINSCP_PATH% /script=%SCRIPT_PATH% /log=%LOG_PATH% /loglevel=2 ) else ( echo No CSV files found to delete ) REM Clean up del %TEMP_SCRIPT% del output.txt endlocal
Site Admin -
- 43,223
- Prague, Czechia
Re: if exist rm file not working in batch script
For such complex scripts, you better use WinSCP .NET assembly, e.g. from PowerShell:
Using WinSCP .NET Assembly from PowerShell
