How to get list of folders when using batch
I am using "batch" and I can't get my head around how can I pull list of subfolders from parent folder on FTP site. Here is the script I use. Thanks a lot =)
string ftpDetails = "ftp://xxx@xxx.org.uk:xxxxxx@ftp.xxxxxx.co.uk:990 -implicit"; string batchFileName = @"\\xxx\xxx\xxx\Julia\TEST_Images\Transfer\batch.txt"; string logFileName = @"\\xxx\xxx\xxx\Julia\TEST_Images\Transfer\ftp.log"; string sourceFolder = "/xxx/xxx/Export/Images"; //this is parent FTP folder string destinationFolder = @"\\xxx\xxx\xxx\Julia\TEST_Images\Transfer\Live\"; //this is On-Premise folder string batch = "option batch on" + Environment.NewLine + "option confirm off" + Environment.NewLine + "open " + ftpDetails + Environment.NewLine + "cd " + sourceFolder + Environment.NewLine + "option transfer binary" + Environment.NewLine + //"get " + sourceFolder + Environment.NewLine + //no luck //"get " + sourceFolder + "/" + Environment.NewLine + //no luck //"get " + sourceFolder + "/*" + Environment.NewLine + //no luck //"get " + sourceFolder + "//*" + Environment.NewLine + //no luck "close" + Environment.NewLine + "close" + Environment.NewLine + "exit" + Environment.NewLine ; File.WriteAllText(batchFileName, batch); string arg = "\"/script=" + batchFileName + "\" /log=\"" + logFileName + "\""; ProcessStartInfo info = new ProcessStartInfo(@"\\care-sql-prd01\winscp$\WinSCP.com", arg); Process p = new Process(); p.StartInfo = info; p.Start(); p.WaitForExit();
