Session.CompareDirectories issue with FileTransferProgressEventArgs.OverallProgress
geek569
FileTransferProgressEventArgs.FileProgress and FileTransferProgressEventArgs.OverallProgress are reported equals by Session.CompareDirectories() and ComparisonDifference.Resolve().
Re: Session.CompareDirectories issue with FileTransferProgressEventArgs.OverallProgress
The Session.CompareDirectories should not even trigger the Session.FileTransferProgress event – as Session.CompareDirectories does not do any transfer.
The ComparisonDifference.Resolve typically transfers a single file only (unless the difference is a new folder). So indeed FileTransferProgressEventArgs.FileProgress and FileTransferProgressEventArgs.OverallProgress would be equal.
Sorry, but what you are you asking for? For an overall progress over multiple Resolve calls? You would have to calculate it on your own, based on ComparisonDifference.Local/Remote.Length.
geek569
I mean how to get the right OverallProgress in FileTransferProgress when using ComparisonDifference.Resolve()
session.FileTransferProgress += (s, e) =>
   Log($"{e.FileName} | {e.CPS}/s | {e.FileProgress:P0} | {OverallProgress???}");
