Permissions
prasadgov
Permissions
Currently, I run my automated WinSCP script to download files from a FTP server and it is fine.
In my work machine, the Win.exe is in C:\software\winscp\ and I download the files in the same location.
When I try to change the local directory to C:\download\DailyFiles\ it fails.
It says parameters is incorrect and Can't get the attributes of the 'C:\download'.
Is it permissions issue? Should I run it from the same path where the exe is?
TIA
Re: Permissions
