Is appending PDFs to each other possible?
Matt
I don't know if I'd need something else for this, but I want to write a script that runs once daily and fetches PDFs from an FTP directory.
The name is basically:
xxxxx-n1.pdf
xxxxx-n1-yyyyy.pdf
xxxxx-n1-zzzzz.pdf
xxxxx-n2.pdf
xxxxx-n2-yyyyy.pdf
xxxxx-n2-zzzzz.pdf
Would it be possible to merge all files with the same "n" into one PDF file when downloading, or would I need an outside tool and script for this?
Thank you for any advice. :)
Re: Is appending PDFs to each other possible?
WinSCP can append files. But you cannot append PDFs to merge them, afaik. And WinSCP cannot merge PDFs. You need another tool.
Matt
Yeah, today I read around a bit and found PDFtk which allowed me to do what I was set out to do. :) Thank you for replying!
