Schedule remote to remote job
Uterus
Sweden
Hey
I want to schedule a transfer via Task Scheduler from one remote server to remote FTP
So far I've created a task that opens "C:\Program Files (x86)\WinSCP\WinSCP.com" with added argument: in a single line.
"/log=D:\Logfilepath\log.txt /command "open ftp://username:password@FTPURL:port" "put ""\\source\folder\subfolder\sub folder\subbfolder\subfolder\*"" TargetURL/ "exit"
But as soon as I add multiple put-commands nothing works.
Ideally I want to have all my arguments on file, not inputed directly to task scheduler.
Re: Schedule remote to remote job
Even your single-put commandline is wrong, so it probably does not work correctly either. It misses one quote. It should be:
"put ""\\source\folder\subfolder\sub folder\subbfolder\subfolder\*"" TargetURL/" "exit"
https://winscp.net/eng/docs/commandline#syntax
If by your last sentence you mean that you want to have the commands in a file, then use /script parameter:
https://winscp.net/eng/docs/commandline#scripting
