The value supplied is not valid, or the property is read-only. Change the value, and then try again.
Starman
Portugal
In PowerShell, I have this file:
# Load environment variables from .env file
$envFile = ".env"
if (Test-Path $envFile) {
    $envValues = Get-Content $envFile | ForEach-Object {
        if ($_ -match '\s*([^=]+)\s*=\s*(.+)') {
            $matches[1].Trim(), $matches[2].Trim()
    $envHash = @{}
    for ($i = 0; $i -lt $envValues.Length; $i += 2) {
        $envHash[$envValues[$i]] = $envValues[$i + 1]
else {
    Write-Error "Error: .env file not found"
    Exit 1
# Load WinSCP .NET assembly
Add-Type -Path "C:\Users\vicen\AppData\Local\Programs\WinSCP\WinSCPnet.dll"  # Replace with actual path to WinSCPnet.dll
#try {
    # Setup session options
        HostName = $envHash["HOSTNAME"]
        UserName = $envHash["USERNAME"]
        PortNumber = [int] $envHash["PORT"]
        #SshHostKeyFingerprint = "ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAILH4qdAEbpQSMeOtgvaKE5MZHujoO5xyN8V+PdbWfWAz"
    if ($envHash["PASSWORD"]) {
        $sessionOptions.Password = ConvertTo-SecureString $envHash["PASSWORD"] -AsPlainText -Force
    elseif ($envHash["PRIVATE_KEY_PATH"]) {
        $sessionOptions.SshPrivateKeyPath = $envHash["PRIVATE_KEY_PATH"]
    else {
        Write-Error "Error: Password or private key path not provided in .env file"
        Exit 1
    try {
        # Connect
        # Upload files
        $transferResult = $session.PutFiles($envHash["LOCAL_FILE"], $envHash["REMOTE_DIR"], $false, $transferOptions)
        # Throw on any error
        $transferResult.Check()
        # Print results
        foreach ($transfer in $transferResult.Transfers) {
            Write-Host ("Upload of {0} succeeded" -f $transfer.FileName)
    finally {
        # Disconnect, clean up
        $session.Dispose()
#catch {
#    Write-Host ("Error: {0}" -f $_.Exception.Message)
#    Exit 1
With the line that sets SshHostKeyFingerprint commented out, I get
SessionOptions.Protocol is Protocol.Sftp or Protocol.Scp, but SessionOptions.SshHostKeyFingerprint is not set.
However, if I set it, it says
along with the previous error.
I cannot figure out what I'm doing wrong, tbh, I don't use PowerShell scripts that much, but anyway.
I patiently await your response, bye.
Re: The value supplied is not valid, or the property is read-only. Change the value, and then try again.
The value is indeed not a in a format that WinSCP accepts. It misses key size between the key type and the fingerprint. And the actual fingerprint has a wrong length.
See https://winscp.net/eng/docs/faq_hostkey#automation
For general information also see SSH host key/TLS host certificate fingerprint “…” does not match pattern “…”.
