Change client
Hollywood
earth
Change client
HI,
New here. I have been using WinSCP to manage several piCorePlayers.
Obviously the left screen is my local PC and the right screen is the remote client. I state this in case my terminology is wrong, at least you know what I mean.
After completing changes in a session, can I open a different client (IP), REPLACE the current remote IP?
So far, I see how to add a new tab (I don't want to do that as I am old and get confused easily with multiple open sessions) or close WinSCP and restart it. I have all of my players IP's and passwords saved in WinSCP.
I am guessing there is that option, but there are so many options, I can't find it.
Thanks!
Re: Change client
If I understand you correctly, you want to keep the local/left panel unchanged while opening new session in remote/right panel.
To do that, in preferences, enable Do not change state when switching sessions in Local panel preferences:
https://winscp.net/eng/docs/ui_pref_panels_local
Then after you close the tab/session, a Login dialog pops up, and once you open a new session, the left/local panel stays at it was and you will have new session/server in the right/remote panel.
Hollywood
earth
close!
Thanks for replying! Your reply was part of the answer, and it pointed me in the right direction. I now see how to do what I wanted in the original post. Click on Tabs, then Disconnect, then Tabs again, and Sites.
If you did nothing, this works perfect. If you wanted, a Disconnect button over the remote pane would be nice, perhaps with a drop down to choose Disconnect, or Disconnect and Sites (one click).
Your suggestion "enable Do not change state when switching sessions in Local panel" applies too.
Thanks again!
