FTP download of .zip file not working
jhorsewood@gmail.com
North Carolina
First time user with WinSCP 6.3.3 on Windows 11 attempting FTP transfer of large .zip file.
Installed software using Commander GUI.
Login to remote site works perfectly. Tried drag-and-drop of compressed file to downloads folder on local machine and nothing happens. Queue reports 0 KB transferred and progress Completed. After reading applicable documentation, I see nothing wrong with what I am doing. What could I be missing?
Re: FTP download of .zip file not working
Please attach a full session log file showing the problem and a successful consecutive transfer (using the latest version of WinSCP).
Also, does the problem happen even with a foreground transfer (not using queue)? Did you try the same using any other FTP client? Can you post its log file too?
Test if it works with FileZilla. If it does then its a WinSCP issue I've seen. If it doesn't then you don't have a client specific issue at all :)
