Get command not working
id10t
I have setup a script that needs to bring over files from a remote directory to a local directory, ignore the Archive subfolder in the remote directory, and then delete the files in the remote directory after a successful transfer.
I cannot get the get command to work.
It states:
No such file or directory
Error Code: 2.
But I have both the Remote Directory and Local Directory set in the script (and also defined in the Advanced Site Settings Directories settings).
What I am doing wrong here?
I've pasted in the script below. Please let me know if you need anymore info.
Thanks.
#Set to batch mode
option batch continue
#No prompting
#Exclude sub folders
option exclude /*
#Open the Oracle_Test_Invoice session
open Oracle_Test_Invoices
lcd d:\groups\Oracle Invoices
get /GFI/ToWMS/IN/Invoice/*.*
Re: Get command not working
Is /GFI/ToWMS/IN/Invoice/ really a correct absolute path? Isn't the GFI a subfolder of your home directory?
If this does not help, please post log both from WinSCP script and from GUI (showing a successful download of the files you cannot download in the script).
id10t
Hi Martin,
/GFI/ToWMS/IN/Invoice/ is the absolute path where the files are located in the remote directory (with an ARCHIVE sub directory that needs to be excluded).
I've attached the screenshots where it will successfully transfer from the GUI but not the script.
Please let me know if you need anything else.
