Session has unexpectedly closed
ChartFast Support
Hi Team,
Need guidance for on the below:
File Exception : Message : Session has unexpectedly closed InnerException : Stack Trace : at WinSCP.SessionElementLogReader.Read(LogReadFlags flags) at WinSCP.CustomLogReader.TryWaitForNonEmptyElement(String localName, LogReadFlags flags) at WinSCP.CustomLogReader.WaitForNonEmptyElement(String localName, LogReadFlags flags) at WinSCP.Session.PutFiles(String localPath, String remotePath, Boolean remove, TransferOptions options)
Re: Session has unexpectedly closed
Are you really having five different problems at the same time? Or did you made some progress and only one of the problems is your current one?
In any case, none of your posts contain enough information. We need log files at the very least – Session.SessionLogPath and Session.DebugLogFile.
