Problems move files - Error permited denied
carla.duarte
brasil
I am problems move files - error
Permission denied.
Error code: 3
Error message from server: Permission denied ao mover o arquivo /teste/Teste1.xlsx para /teste1/Teste1.xlsx.
at WinSCP.SessionLogReader.Read(LogReadFlags flags)
at WinSCP.ElementLogReader.Read(LogReadFlags flags)
at WinSCP.SessionElementLogReader.Read(LogReadFlags flags)
at WinSCP.CustomLogReader.TryWaitForNonEmptyElement(String localName, LogReadFlags flags)
at WinSCP.Session.MoveFile(String sourcePath, String targetPath)
Re: Problems move files - Error permited denied
Does the teste1 folder exist? Do you have write permissions there? Can you move the file there in WinSCP GUI? Or in any other client? Post logs.
carla.duarte
Realizando via WINSCP.exe funciona normalmente mover o arquivo com o usuário. Se chamo o método via código .net lança a exception.
Log XML WinSCP
<?xml version="1.0" encoding="UTF-8"?>
<session xmlns="http://winscp.net/schema/session/1.0" name="******CTG7Y5@****150673.rm.cloudtotvs.com.br" start="2024-06-11T13:48:07.329Z">
<mv>
<filename value="/Arquivos_legado/Pendentes/AlteracaoSecao.xlsx" />
<destination value="/Arquivos_legado/Processados/AlteracaoSecao.xlsx" />
<result success="true" />
</mv>
<mv>
<filename value="/Arquivos_legado/Processados/AlteracaoSecao.xlsx" />
<destination value="/Arquivos_legado/Pendentes/AlteracaoSecao.xlsx" />
</mv>
Log xml .Net
<session xmlns="http://winscp.net/schema/session/1.0" name="******CTG7Y5@****150673.rm.cloudtotvs.com.br" start="2024-06-11T14:05:39.245Z">
<group name="open sftp://******CTG7Y5@****150673.rm.cloudtotvs.com.br:2323 -hostkey=&quot;*&quot; -timeout=15" start="2024-06-11T14:05:39.878Z">
</group>
<group name="pwd" start="2024-06-11T14:05:40.049Z">
<cwd>
<cwd value="/" />
</cwd>
</group>
<group name="stat -- &quot;/Arquivos_Legado/processados/AlteracaoSecao.xlsx&quot;" start="2024-06-11T14:05:41.827Z">
<stat>
<filename value="/Arquivos_Legado/processados/AlteracaoSecao.xlsx" />
<result success="false">
<message>Can't get attributes of file '/Arquivos_Legado/processados/AlteracaoSecao.xlsx'.</message>
<message>No such file or directory.
Error code: 2
Error message from server: No such file</message>
</result>
</stat>
<failure>
Error code: 2
</failure>
</group>
<group name="mv &quot;/Arquivos_Legado/Pendentes/AlteracaoSecao.xlsx&quot; &quot;/Arquivos_Legado/Processados/AlteracaoSecao.xlsx&quot;" start="2024-06-11T14:06:45.687Z">
<failure>
<message>Error moving file '/Arquivos_Legado/Pendentes/AlteracaoSecao.xlsx' to '/Arquivos_Legado/Processados/AlteracaoSecao.xlsx'.</message>
<message>Permission denied.
Error code: 3
Error message from server: Permission denied</message>
</failure>
<mv>
<filename value="/Arquivos_Legado/Pendentes/AlteracaoSecao.xlsx" />
<destination value="/Arquivos_Legado/Processados/AlteracaoSecao.xlsx" />
Error code: 3
</result>
</mv>
</group>
