Default drag and drop action.
KWH
NorthWest
For years the default drag and drop action between commander windows has bee copy. Suddenly, it is using MOVE. How do i get copy back as default?
Re: Default drag and drop action.
Do you really mean dragging between local and remote panels of the same WinSCP window? Does it happen for local => remote or remote => local or both?
KWH
NorthWest
RE: Drag and drop copy
You are correct in that I am asking about local to remote and remote to local transfers. After using WinSCP for several years I found I had lost several files because the default transfer had become MOVE rather than copy. I looked through all the "Options --Preferences" and didn't see anything I recognized as helpful. In desperation, I started checking boxes.
Whether it was this act of stupidity or something else, the default is again copy. BUT, I would like to know how this can be done/undone for future problems.
Thank you for your response
Re: RE: Drag and drop copy
The default drag&drop operation between local and remote panels should always be Copy. No option should change it. If you ever face the problem again, please let us know.
