Task scheduling no longer works
StRe
DE
Hello everyone,
I have been using WinSCP Portable on my Windows 2019 Server for years and run a script file every hour with the task scheduler. Suddenly, for reasons I can't explain, files are no longer being transferred from the source to the destination. The task scheduler says "The process was completed successfully". If I run the script from the command prompt, it works. The script does the following:
open XYZ
synchronize remote "\\SERVER01\transfer$\Shop" /public_html/shop-domain.de/web/var/wawi/products/ -mirror
Do you have an idea?
Re: Task scheduling no longer works
Please attach a full session log file showing the problem. Both from the scheduled and the manual run.
StRe
DE
Hi Martin,
sorry for asking, but do I have to include the command in the script?
My script currently looks like this:
option batch abort
open Shopware6
put "\\SERVER01\transfer$\folder\folder\*" *
synchronize remote "\\SERVER01\transfer$\folder\folder" / -mirror
If yes, where? Can you please show me an example?
StRe
DE
Hi Martin,
sorry, misunderstanding on my part...
I have now rebuilt the script and directly specified the SFTP server including user name and password in the open command. Now the script works again via the task planner.
It's just inexplicable to me why this is/was like this from one day to the next?
StRe
DE
Unfortunately I don't quite understand what you mean :-(
Processing via the task planner always worked 100% smoothly and reliably. I hadn't changed anything in the script or the task planner. From one day to the next, execution via the task planner simply stopped working. If I ran the script manually via Command, everything worked wonderfully.
Unfortunately, I don't understand why execution via the task planner stopped working from one day to the next?
