Process does not exit when using TortoisePlink as local proxy command
Rayz
I use the proxy and the tunnel features at the same time, the local proxy command is:
TortoisePlink %user@%proxyhost -P xxx -pw xxxx -nc %host:%port
It works well, but I found the TortoisePlink process still living when the WinSCP window closed.
Is it a bug? I think the child process should be closed when the parent process existing.
Re: Process does not exit when using TortoisePlink as local proxy command
I cannot reproduce the problem. Please attach a full session log file showing the problem (using the latest version of WinSCP).
