- kelvin01
- 1
compare directories and subdirectories
it would be nice if i could compare directories recursive so i don't have to look in every directory to see if something changed
- RubenKonig
- 1
Re: compare directories and subdirectories
I do agree, but even without that functionality, the directory comparison tool is a great tool. Recursive directory comparison would be a really great tool. Good work.
Janssen
(recursive) directory comparison AND synchronization options
(recursive) directory comparison & synchronization options are the things I would like to see.
- nthan15
- 1
count me in... i'd like to see this feature too
Me too!
I would also like to see the syncronize feature extended to subdiectories. If you are using windows API call to do the synchronisation i.e. ReadDirectoryChangesW then the third parameter is a boolean that just needs to be set true to enable this (bWatchSubtree). This should probably be an option in the "More" dialog of this window however.
guest22
i completely agree.
winscp is great for transferring files via scp or sftp.
but with robust tools for recursive synchronization, directory comparison, etc. winscp could be a great tool for remote development.
compare timestamps for files. options for updating certain files.
synchronize including delete extraneous files on local drive not present on remote checkbox vice versa
:D :D :D :D
:D :D :D :D
Fris
Some other nice features I could use and possibly other people too :-)
Monitoring file deletions, thus ensuring complete real-time synchronization.
Bandwith limit (seen in another synchronization tool): by telling WinSCP not to use more than a certain amount of bandwith other network traffic can also still pass at the same time (especially usefull for slower connections, of course).
Option to update the remote directory only at a specified interval. Very usefull if you have to save your files very often, but don't want them to be uploaded every time.
- Guest
sunc
i have a remote server and want to backup the files everyday...
an option to schedule a synchronization between 2 folder(incl. subfolders) everyday would be very nice option
VBplaya
I agree 2
I also need this function. Please implement it in your next version.
guest
Re: (recursive) directory comparison AND synchronization options
I really really want to see sychronization too!!!
Here is my added problem, What I'm trying to keep in sync is around 10 Gigs, and I didn't want to transfer it all with winscp the first time so I did that directly with a laptop. Anyway, the timestamps are totally different for everything and there is no way to change what attributes are being used to compare the files and directories. I would be happy at this point with file name and file size being compared. As it is now, it's highlighting everything when I compare directories.
Site Admin -
- 43,224
- Prague, Czechia
Good idea, I'll implement it.I would be happy at this point with file name and file size being compared. As it is now, it's highlighting everything when I compare directories.
- Marena
- 1
- Czechia
Watch out - comparing file size is not always good idea. When you transfer text files between Windows and Unix you'll have always different size...
Marena
Marena
Site Admin -
Of course, it will be optional and off by default.Watch out - comparing file size is not always good idea. When you transfer text files between Windows and Unix you'll have always different size...
