Cannot locate TLS 1.2 enable option
Daniel192
I am using WinSCP version 6.3.2 and when I follow the documentation located https://winscp.net/eng/docs/ui_login_tls I cannot locate a tick box to enable TLS 1.2.
The screenshot in that documentation does not seem to match the version that I am using.
Am I looking in the wrong location in the app? Can someone please advise how I can enable and/or force TLS 1.2?
Thank you
Re: Cannot locate TLS 1.2 enable option
That documentation/screenshot is up-to-date and the window should look like that in WinSCP 6.3.2.
Make sure you have selected a protocol that uses TLS (FTP, WebDAV, S3) and enabled TLS encryption, before you open the Advanced Site Settings dialog.
Also, note that TLS 1.2 is enabled by default.
