Download last two weeks of files from a FTP folder
gilbreen
There are two files generated every day by one of our partner agencies, one in the morning and one in the evening and they are placed on their FTP site. The file's naming structure starts with the current date and then adds a randomly generated number.
Their FTP site holds all generated files going back to June 2022. We currently use a script with WinSCP to synchronize their FTP site to a local folder which means our local folder contains all files going back to June 2022.
Our agency only needs the last two weeks of files at any give time. Instead of keeping all the files back to June 2022 in our local folder, is there a way to have WinSCP only download/synchronize the files for the last two weeks?
Re: Download last two weeks of files from a FTP folder
It's easy if you can rely on file timestamps:
get /remote/path/*>14D
See https://winscp.net/eng/docs/file_mask#size_time
If you have to rely on the date in the filename, it is more difficult. You can use 14 get commands, one for each day (or one command with 14 masks):
cd /remote/path
get %TIMESTAMP#yyyy-mm-dd%*
get %TIMESTAMP-1D#yyyy-mm-dd%*
get %TIMESTAMP-2D#yyyy-mm-dd%*
get %TIMESTAMP-13D#yyyy-mm-dd%*
(assumes that filename has format yyyy-mm-dd*)
See https://winscp.net/eng/docs/scripting#timestamp
gilbreen
Thank you for the assistance. I adjusted our script and the first time the script ran, it downloaded the last 14 days of files. However, on subsequent runs of the script, it downloads the newer files, but is not removing the files that are older than 14 days.
The current script contains the following:
option batch on
open ftp://remote_ftp_site
option transfer binary
get /remote/path/*>14D v:\Test\*
Where v: is one of the local drives and I created the Test folder as the destination.
Is there a way to adjust the script so it deletes the files that no longer meet the 14 day requirement?
If you do not need the old files, just delete complete v:\Test before even starting WinSCP script.
gilbreen
Just following up that everything is working as expected. I created separate task to remove the contents of the folder prior to the automated syncing and it is working great. Thanks for the help!
