Issue after configuring WinSCP to use SFTP and port 22
xeccf8v
After configuring WinSCP to use SFTP and port 22, the connection fail and when running the
net stat command netstat -ano | findstr ":21" we noticed that WinSCP is still trying to connect using port 21.
Re: Issue after configuring WinSCP to use SFTP and port 22
Please post a screenshot of your WinSCP session settings and corresponding log file.
Domin
I can not log in
Hello, I have a problem when I log in, I enter the hosting name, username and password, everything is entered correctly and I click log in, then everything disappears. I tried uninstalling WinSCP and installing it and still nothing worked
Re: I can not log in
@Domin: Please attach a full session log file showing the problem (using the latest version of WinSCP).
