Multiple file mask help
RodneyAllen
UK
Hello all
I am trying to include files less than a day old and exclude files that contain Merge using the following WinSCP PowerShell script. Is there something I can rewrite to have both masks work every time please? Let me know if you need any further info.
# Connect
$emailBody += "`n[$(get-date -f G)] Session opened"
# Transfer files
$transferOptions.FileMask = "|*_Merges_*;<1D";
In the log files in test using a handpicked selection of files this seems to work, as follows
. 2024-04-16 10:04:05.876 Transfer done: 'D:\ftp\Oxleas\RiO_Admissions_OXLEAS_20240415211802.CSV' => '/oxleasRIO/RiO_Admissions_OXLEAS_20240415211802.CSV' [11512] Less than day old ok
. 2024-04-16 10:04:05.876 Deleting successfully uploaded source file "D:\ftp\Oxleas\RiO_Admissions_OXLEAS_20240415211802.CSV".
. 2024-04-16 10:04:05.891 File "D:\ftp\Oxleas\RiO_Alerts_OXLEAS_20240413211801.CSV" excluded from transfer
* 2024-04-16 10:04:05.891 (ESkipFile) older than a day skipped
. 2024-04-16 10:04:05.891 File "D:\ftp\Oxleas\RiO_Alerts_OXLEAS_20240414211802.CSV" excluded from transfer
. 2024-04-16 10:04:05.891 File "D:\ftp\Oxleas\RiO_Merges_OXLEAS_20240409211801.CSV" excluded from transfer
* 2024-04-16 10:04:05.891 (ESkipFile) filename contains merge skipped
However in live using the same script on the same server with live data feed Merges are skipped but old files are not
. 2024-04-17 07:15:51.658 File "D:\ftp\Oxleas\RiO_Merges_OXLEAS_20240416211801.CSV" excluded from transfer
* 2024-04-17 07:15:51.658 (ESkipFile) merge skipped
. 2024-04-17 07:15:51.658 File: 'D:\ftp\Oxleas\RiO_MHCareCoordinator_OXLEAS_20240203211801.CSV' [2024-04-17T06:04:34.399Z] [32]
. 2024-04-17 07:15:51.658 Copying "D:\ftp\Oxleas\RiO_MHCareCoordinator_OXLEAS_20240203211801.CSV" to remote directory started.
< 2024-04-17 07:15:51.674 Status code: 0
. 2024-04-17 07:15:51.674 Transfer done: 'D:\ftp\Oxleas\RiO_MHCareCoordinator_OXLEAS_20240203211801.CSV' => '/oxleasRIO/RiO_MHCareCoordinator_OXLEAS_20240203211801.CSV' [32] unwanted old file copied
. 2024-04-17 07:15:51.674 Deleting successfully uploaded source file "D:\ftp\Oxleas\RiO_MHCareCoordinator_OXLEAS_20240203211801.CSV".
RodneyAllen
UK
hello Martin
appreciate the help but unfortunately now nothing is skipped, old or Merge files. Can you help please?
> 2024-04-19 07:15:05.134 Script: put -delete -nopermissions -preservetime -transfer="binary" -filemask="|*_Merges_*<1D" --
. 2024-04-19 07:15:39.681 Transfer done: 'D:\ftp\Oxleas\RiO_Demographics_OXLEAS_20240414211802.CSV' => '/oxleasRIO/RiO_Demographics_OXLEAS_20240414211802.CSV' [11753]
. 2024-04-19 07:15:40.009 Transfer done: 'D:\ftp\Oxleas\RiO_Merges_OXLEAS_20240203211801.CSV' => '/oxleasRIO/RiO_Merges_OXLEAS_20240203211801.CSV' [32]
RodneyAllen
UK
Many thanks again for your time Martin
unfortunately now everything was blocked and nothing uploaded !
My effort has been that I couldn't get the syntax but really appreciate your help :). Do you need any details further or help please?
> 2024-04-23 07:15:08.190 Script: put -delete -nopermissions -preservetime -transfer="binary" -filemask="<1D | *_Merges_*" -- ...
but files less than day excluded not included
. 2024-04-23 07:15:08.408 File "D:\ftp\Oxleas\RiO_Admissions_OXLEAS_20240422211802.CSV" excluded from transfer
* 2024-04-23 07:15:08.408 (ESkipFile)
Hello Martin
I'm arranging the upgrade and in meantime please find the last session log attached
Thank you again for your help
  • OXRIO_2024-04-25.txt (166.63 KB, Private file)
Description: redacted session log attached
