Special symbols in folder/filenames
DnsIs
Good day.
I don’t understand what to do if there are special characters in the file names.
A simple script for downloading files from the server:
open ....
cd /dl
lcd C:\dl
get _%3A_.log
get test.log
Works great, but file _%3A_.log arrives renamed to _%253A_.log. Which is not very good.
A simple script to upload a file to the server:
open ....
cd /dl
lcd C:\dl
put _%3A_.log
put test.log
Let's look at the log:
Copying "_%3A_.log" to remote directory started.
Status code: 10, Message: 771, Server: The file path does not exist or is invalid., Language: en
(ETerminal) File path does not exist or is incorrect
Can't create a file on the server '/dl/_:_.log'. ("The file path does not exist or is incorrect
Error code: 10
Two problems:
The first is that we cannot load the _%3A_.log file
The second problem is that the error interrupts the execution of the script and the next test.log file is not copied.
