Incompatible external console protocol version 9
SteHRfan
we make an automated backup from our ticket system witch following skript:
param (
    $localPath = "C:\Backups",
    $remotePath = "/export"
try
    # Load WinSCP .NET assembly
    Add-Type -Path "C:\Program Files\Zammad-Backup-Downloader\WinSCPnet.dll"
    # Setup session options
        HostName = "here.there.com"
        UserName = "abcdefgh"
        SshHostKeyFingerprint = "ssh-ed25519 255 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" (is changed)
        SshPrivateKeyPath = "C:\SSH\private.ppk"
    try
        # Connect
        # Get list of files in the directory
        $directoryInfo = $session.ListDirectory($remotePath)
        # Select the most recent file
        $latest =
            $directoryInfo.Files |
            Where-Object { -Not $_.IsDirectory } |
            Sort-Object LastWriteTime -Descending |
            Select-Object -First 1
        # Any file at all?
        if ($latest -eq $Null)
            Write-Host "No file found"
            exit 1
        # Download the selected file
        $session.GetFileToDirectory($latest.FullName, $localPath) | Out-Null
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
This works some years with WinSCP V5.The ticket system support told me that I have to change to the newer version of WinSCP. So I downloaded the WinSCP-6.3.1-Portable.zip an put them to the folder where the old version was stored.
With that I got the Error
Zammad-Backup-Downloader\Download-Zammad-Backup.ps1
Error: Ausnahme beim Aufrufen von "Open" mit 1 Argument(en): "The version of C:\Program Files\Backup\winscp.exe (6.3.1.0) does not match version of this assembly C:\Program Files\Backup\WinSCPnet.dll (5.17.10.0).
So I downloaded the WinSCP-6.3.1-Automation.zip and saved the files in that folder.
Now I got the following error:
Incompatible external console protocol version 9.
What I have to change?
Best regards
Re: Incompatible external console protocol version 9
I do not think you can get "Incompatible external console protocol version 9" error with your current code. Aren't you actually setting DisableVersionCheck property?
Anyway, you still have some binary outdated.
You are not very specific regarding the folders, where you replaced the binaries. So it is difficult to help you.
Anyway, extracting the WinSCP-6.3.1-Automation.zip package to C:\Program Files\Zammad-Backup-Downloader should help.
If it does not work, please post debug log file (Session.DebugLogPath).
