FTP over SSL/TLS not working
fastcoder
. 2024-02-08 10:31:19.445 Read 16 bytes
< 2024-02-08 10:31:19.459 200 'TYPE' OK.
> 2024-02-08 10:31:19.459 PASV
. 2024-02-08 10:31:19.554 TLS connect: SSL negotiation finished successfully
. 2024-02-08 10:31:19.554 TLS connect: SSLv3/TLS read server session ticket
. 2024-02-08 10:31:19.554 Read 49 bytes
< 2024-02-08 10:31:19.554 227 Entering Passive Mode (102,208,217,16,4,20)
> 2024-02-08 10:31:19.554 MLSD
. 2024-02-08 10:31:19.554 Connecting to 102.208.217.16:1044 ...
. 2024-02-08 10:31:19.554 Connection pending
. 2024-02-08 10:31:19.664 Read 38 bytes
< 2024-02-08 10:31:19.664 150 Opening 'ASCII' data connection.
. 2024-02-08 10:31:19.664 Data connection opened
. 2024-02-08 10:31:19.664 TLS layer changed state from none to connected
. 2024-02-08 10:31:19.774 Read 135 bytes
< 2024-02-08 10:31:19.774 425-Rejecting data connection from xx.xx.xx.xx1 (only xx.xx.xx.2 is allowed).
< 2024-02-08 10:31:19.774 425 Closing data connection; transfer not started.
. 2024-02-08 10:31:19.774 Destroying data socket on error
. 2024-02-08 10:31:19.774 Could not retrieve directory listing
. 2024-02-08 10:31:19.774 Got reply 4 to the command 2
. 2024-02-08 10:31:19.774 Session upkeep
fastcoder
Those are NAT IP addresses.
Both are correct.
I have tried only with WinSCP so far.
Any configuration on WinSCP side which can help?
This imo completely out of (FTP) client's control. (The comments at your SU post already indicate that).
You can try the active transfer mode. But that requires opening local firewall. I wouldn't recommend that.
