error:0308010C:digital envelope routines::unsupported after upgrade
Timeruler
Hello
We have been using WinSCP to connect to FTPS for a couple of years without any issues.
We recently upgrade to new certificate for connection, again without any issues.
But after upgrading WinSCP from version 5.19.6 to 6.3.1 we cannot establish FTPS connection.
We get following error message:
Cannot read certificate "D:\Scripts\XXXXXXXX.pfx".
We tried to upgrade OpenSSL to latest version on server, but that didn't have any impact.
We ended up rolling back to version 5.19.6 and everything was running again.
Re: error:0308010C:digital envelope routines::unsupported after upgrade
How did you get/generate the PFX?
Timeruler
Hello
it's from the danish goverment used to identify company.
OCES3 they are called here in Denmark.
itermediate:
C = DK
O = Den Danske Stat
CN = Den Danske Stat OCES udstedende-CA 1
Root CA:
C = DK
O = Den Danske Stat
CN = Den Danske Stat OCES rod-CA
Don't know if you can use that.
regards,
Lasse
Don't you have some maybe expired or otherwise invalid certificate of the same type/format that might be able to share with us?
Timeruler
I would love to provide you with it, but the CA and Intermediate CA are jus under 8 months old as far as I know.
And as such I don't have access to an expired certificate.
I would be happy to provide you with as much details as possible, but i cannot provide a complete certificate.
I'll get back to you on that.
Looks promising, just got at few issues in other departments I need to take care of :D
Thank you for the suggestion.
Love your product
Timeruler
Hello Martin
I've now had a chance to look into the certificate, and the above mentioned link provided some excellent commands to verify the certificate.
And indeed our certificate seems to have an outdated encryption.
Suspect it's because it's an export from a keystore as mentioned in the article.
Running the openssl command (3.x) gave following information (passphrase needed):
openssl pkcs12 -in "x:\xxxx\xxx\XXXXX.pfx" -info -nokeys -nocerts
Info:
PKCS7 Encrypted data: pbeWithSHA1And40BitRC2-CBC, Iteration 1024
When we have time well try to use the info from the article to make a reencryption of the certificate an see if it will work with latest version of WinSCP
Thank you for the help
