Error transferring a file when it contains the character "–".
rrdein
USA
I was transferring some files and 2 files would not transfer. The error was "No such file or directory" which of course made no sense. I noticed the two files had a hyphen that was different from other hyphens. The character was –. I don't need a resolution but I'm reporting it so that it can be fixed, if so desired. My OS (Windows) didn't reject that character, so my FTP client (I was using FTP specifically) also should not reject it, in my view, so I feel that this is a bug which should be corrected. I have seen other report the same error with no resolution, so perhaps non-ASCII characters are the cause.
Re: Error transferring a file when it contains the character "–".
