Error 0x80004005 when copying files to local directory after copying from remote dir
HCP936
Customer
USA
I keep getting the Error 0x80004005: Unspecified Error when I try to copy a file from remote directory to local directory from GUI. The progress bar for copying shows that it gets downloaded to the temp directory but does not get transferred to the directory where I want it to be copied. This has been going on for at least the past 4 months. I have tried both copying a fake file method and copying via a temp copy and then transfer.
WinSCP 6.3, Win 11 OS Build 22631.3155.
Description: Log shows me trying to copy by right click --> copy to click board done twice with the error popping up in a error window and then trying a drag and drop type copy to copy the file which is successfull. The log may have recorded some slight activity af
Re: Error 0x80004005 when copying files to local directory after copying from remote dir
