Allow skip PuTTY sessions for a connection
Deadken
US
I work with a few SFTP sites which don't allow SSH sessions.
This opens a PuTTY window which then shows the rejected session. It would be nice to be able to skip the automatic sessions.
Deadken
Correct, but I have roughly 100 sites I connect to. Most allow SSH connections, but a couple do not. This is why is would be nice if this could be disabled on a per-site basis.
Not a major issue, but just a nice convenience.
So would it work for you, if you disable the automatic opening? And you just manually open PuTTY from WinSCP, whenever you need it? – Ctrl+P
