WinSCP 6.3 | Error 5 on any MOVE command with SFTP
fwx3
We're noticing 6.3 has issues moving files. It can upload/download OK but any move throws "Error code: 5". This is even with the .filepart being removed at completion of a transfer. This is also happening with multiple different SFTP server software.
Bad message (badly formatted packet or protocol incompatibility).
Error code: 5
Error message from server (en): Badly formatted SFTP packet
Session information:
File transfer protocol = SFTP-6
Cryptographic protocol = SSH-2
SSH implementation = [redacted]
Encryption algorithm = [redacted]
Compression = No
Server host key fingerprints
SHA-256 = [redacted]
MD5 = [redacted]
Can change permissions = Yes
Can change ACL = No
Can change owner/group = No
Can execute arbitrary command = No
Can create symbolic/hard link = Yes/Yes
Can lookup user groups = No
Can duplicate remote files = No
Can check available space = No
Can calculate file checksum = No
Native text (ASCII) mode transfers = Yes
Additional information
The server supports these SFTP extensions:
newline="\r\n"
supported2=0x0000003D000000000000000F000000000000000000000001000000010000000000000000
versions="3,4,5,6"
Re: WinSCP 6.3 | Error 5 on any MOVE command with SFTP
Do you mean that it was working in previous versions of WinSCP and now it does not with WinSCP 6.3?
Please attach a full session log file showing the problem (using the latest version of WinSCP). If it was working in the previous version, please post its log file too. You can download the previous version from:
https://sourceforge.net/projects/winscp/files/WinSCP/
sectorx
I can confirm same problem with 6.3 version. I reverted back to 6.1.1 and problem is gone.
