Facing issue while pasting the path in Open Directory but documents are not uploaded in WinSCP
NileshKpmg
Airtel Center Gurgaon
I am pasting the path in Open directory after clicking on OK documents are not showing in WinSCP.
Reply with quote E-mail
Re: Facing issue while pasting the path in Open Directory but documents are not uploaded in WinSCP
What path is it? Is it a local path or a remote path?
Your question title says "are not uploaded", but the text says "are not showing". So what is correct? And how is either related to the "Open Directory"? Do you mean that you try open a path, but nothing actually happens? Can you post a screen recording?
