Stack Trace when copying PS1 roms to Ras Pi 2 Model B (Batocera BCM2836-36-20230311)
wellbeserious
Pr:
Stack Trace error when copying from Explorer to WinSCP session (SFTP, pre-saved, GUI, Explorer interface).
TASK:
Copying many PS1 roms from computer to Ras Pi 2 Model B V1.1, "Batocera Linux BCM2836-36-20230311" for Ras Pi 2. WinSCP was set to continue copying every 1 second, regardless of disconnection (most likely caused by extra-long Ethernet cable; I don't have WiFi USB Adapter yet).
WHAT I DID:
Turn on PC, turn on Ras Pi, (Ras Pi) open Main Menu, (PC) open WinSCP, open Windows Explorer, auto-connect to pre-saved SFTP (default) protocol, (WinSCP) browse to "/roms/psx/", (Explorer) browse to PS1 roms, drag-and-drop many roms (54, including duplicates for tracks), (WinSCP) starts copying. After a while, this error shows up. It didn't when I was only copying "13" roms (finished very slowly, no issue, set speed is at Unlimited), (Ras Pi) restarted. But did when trying to copy remaining "41" roms.
  • Custom Desktop PC
  • ASUS PRIME X570-P MB
  • AMD Ryzen 5 5600X CPU (default clocks)
  • 64GB DDR4 RAM
  • NVIDIA RTX 3050 GPU (default clocks)
  • M.2 SSDs (OS, apps) + HDDs (games)
  • Windows 10 22H2 Build 19045.3996 OS
    • Power plan: High performance
    • Foreground apps: WinSCP 6.1.2 Build 13797 2023-09-19, Windows Explorer
    • Protocol: SFTP, saved credentials to auto-login
    • GUI, Explorer interface
Description: Error "log (.txt) attached. Error copies there, as session is already closed, and I don't know how to recover that session log.
Re: Stack Trace when copying PS1 roms to Ras Pi 2 Model B (Batocera BCM2836-36-20230311)
wellbeserious
UPDATE 2
  • Old version log emailed.
  • New version log emailed.
  • I'm strongly considering using Live Linux to copy-paste those Roms into Batocera's EXT4 partition. Must be far easier than all this.
[COPY OF EMAIL, EXCLUDING LOGS HERE]
OLD VERSION (6.1.2.13797, above):
  • I disabled power saving on Ras Pi. No change.
I tried copying 1 file at a time. Some copied fine, others showed errors for these actions:
Copying Spyro 2: Ripto's Rage
Copying Spyro The Dragon
Copying Street Fighter EX Plus Alpha
Copying Street Fighter EX2 Plus
I then restarted Ras Pi to see if that would fix anything. Only 4 of 41 files show up in Batocera's EmulationStation interface, after restarting and updating gamelists. Of those 41 files, 18 were games, other files were extra tracks. Maybe a problem with Batocera itself. There were 13 other files to be copied, but I replaced WinSCP with Debug (emailed) version, and didn't get a chance.
NEW VERSION (WinSCP-20240213d_master_6.2.5_2eaa691b6-Portable):
  • Ras Pi power saving is disabled.
    • Uninstalled old version.
    • Turned on Ras Pi (boot to main screen).
    • Extracted 'portable' new version to Desktop > opened it.
    • Typed in "host name" (IP address, Username, Password) > Login > Accept (connection).
    • Browsed to "/<root>/userdata/roms/psx" > deleted all files to replicate issue.
    • Opened Explorer > browsed to PS1 roms location (to copy from).
    • (Ras Pi) checked space remaining: 14.35GB. PS1 rom are 13.6GB. More than enough space. 768MB should remain.
    • (WinSCP) changed settings to reconnect every 1 second (on each disconnect), to save time.
      [View > Preferences > Transfer > Endurance > Enable transfer... - All files, 1 second selected for next 3 commands.]
    • (Explorer) Ctrl + A (all rom files) > drag and dropped into WinSCP > (file transfer dialog) OK. 54 files, 13.6GB.
  • Within 1 minute, error appeared:
    "Assertion failed: FPacketReservations -> Items[i] == NULL, file core\SftpFileSystem.cpp, line 1982"
    • OK > error appeared "Abnormal program termination".
    • WinSCP crashed/automatically closed itself. Not able/don't know how to create 'Session Log'. Trace file attached.
ALL PS1 ROM FILES (54 files, 13.6GB):
Crash Bandicoot - Warped (1998).bin
Crash Bandicoot (1996).ccd
Crash Bandicoot (1996).img
Crash Bandicoot 2 - Cortex Strikes Back (1997).bin
Crash Bash (2000).bin
Crash Team Racing (1999).bin
Digimon World (2000).bin
Dragon Ball GT - Final Bout (1997).bin
Dragon Ball Z - Ultimate Battle 22 (2003).bin
Gran Turismo (1.0) (1998).bin
Gran Turismo (1.1) (1998).bin
Gran Turismo 2 (1.1) (Disc 1 - Arcade Mode) (1999).bin
Gran Turismo 2 (1.2) (Disc 2 - Simulation Mode) (1999).bin
Iron Man - X-O Manowar in Heavy Metal (1996).cue
Iron Man - X-O Manowar in Heavy Metal (Track 01) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 02) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 03) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 04) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 05) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 06) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 07) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 08) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 09) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 10) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 11) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 12) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 13) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 14) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 15) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 16) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 17) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 18) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 19) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 20) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 21) (1996).bin
Iron Man - X-O Manowar in Heavy Metal (Track 22) (1996).bin
Mortal Kombat - Special Forces (2000).bin
Mortal Kombat - Special Forces (2000).cue
Silent Hill (1.1) (1999).bin
Spider-Man 2 - Enter Electro (2001).bin
Spyro - Year of the Dragon (1.1) (2000).bin
Spyro 2 - Ripto's Rage! (1999).ccd
Spyro 2 - Ripto's Rage! (1999).img
Spyro the Dragon (1998).bin
Street Fighter EX Plus Alpha (1997).bin
Street Fighter EX2 Plus (1999).bin
Twisted Metal (1995).bin
Twisted Metal 2 (1996).bin
Twisted Metal 4 (1999).bin
Twisted Metal III (1998).bin
X-Men - Children of the Atom (1998).bin
X-Men - Mutant Academy (2000).bin
X-Men - Mutant Academy 2 (2001).bin
X-Men vs. Street Fighter (1998).bin
wellbeserious
Update 3
  • Turned on Ras Pi.
  • (Ras Pi) turned off power saving.
  • Opened "WinSCP-20240216doleg-Portable" (latest emailed version, same extracted copy as used for emailed Trace Files).
  • Enabled Debug 1 logging.
  • Logged into Ras Pi (SFTP).
  • Browsed to:
    /userdata/roms/psx
  • Opened Explorer > browsed to PS1 ROMs location.
  • Dragged-and-dropped "Crash Bandicoot - Warped (1998).bin" into WinSCP.
  • It mostly copied, then this error appeared:
    "Bad message (badly formatted packet or protocol incompatibility).
    Error code: 5
    Error message from server (en): badly encoded SFTP packet"
    > Retry x3 > Abort.
  • Tried copying other files, same error every time.
  • Copied files (all ending with ".filepart"):
  • Debug 1 log + new Trace File:
wellbeserious
Update 4
  • Perhaps the issue is long Ethernet cable or Batocera, not WinSCP. Perhaps lookup network file transfer timeout length in Batocera's documentation (Batocera version BCM2836-36-20230311 For Ras Pi 2).
  • ROMs were copied one-at-a time. Hopefully there won't be problems if copied all at once in same copy session.
  • (Ras Pi) started to main menu.
  • Opened "WinSCP-20240220r_master_6.3.1_2ecd6c615-Portable".
  • Logged into Ras Pi (SFTP, Port 22).
  • Enabled logging (View > Preferences > Logging > "Enable session logging on level - Debug 1" > OK).
  • Browsed to:
    /userdata/roms/psx/
  • Opened explorer > browsed to ROMs location.
  • Dragged-and-dropped "Crash Bandicoot - Warped (1998).bin" > no problems.
  • Dragged-and-dropped these ROMs, one-at-a-time, no errors:
  • Error on ROM "Street Fighter EX2 Plus (1999).bin":
    (0013EA72) KERNELBASE.dll.RaiseException
    (00087A6F) ntdll.dll
    (0055DE74)
    (00E38462)
    (00E39853)
    (00C630F3)
    (00C5ADD9)
    (00C90D6B)
    (00C8F3E8)
    (00C8F215)
    (00C57A2E)
    (00C8EC74)
    (00011F4F)
    (00012B70)
    (0002883D)
    (000289D5)
    (00AF5E86) @TUnixDirView@PerformItemDragDropOperation$qqrp22Vcl@Comctrls@TListItemio
    (00495550)
    (004CA32B)
    (0022E128)
    (00040399) USER32.dll
    (00036B35) USER32.dll
    (0003546C) USER32.dll
    (00034F8B) USER32.dll.DispatchMessageW
  • Closed WinSCP.
Log file (compressed 26.6MB, extracted 411MB):
wellbeserious
Update 5 (3/30)
Sorry for late reply. There are 24 x 1GB 'trace log' files and 1 x 70.7MB file. Which to upload?
What I did:
- Turned on Ras Pi, waited for main menu > turned off power savings.
- Opened WinSCP (emailed version) > typed in Hostname/Username/Password, Login.
- (WinSCP) Browsed to:
/<root>/userdata/roms/psx/
- Dragged-and-dropped these files, one at a time (no problems):
- Copying "Silent Hill (1.1) (1999).bin" resulted in this error window:
Error
Error listing directory '/userdata/roms/psx'.
Out of memory
Please help us improving WinSCP by reporting the error on WinSCP support forum.
(0102063D) C6633_3
(01021C17) _ReThrowException
(00E2427C) TSFTPFileSystem::ReadDirectory
(00E46657) TTerminal::CustomReadDirectory
(00E45B19) TTerminal::ReadDirectory
(00E424E1) TTerminal::DoEndTransaction
(00E42320) TTerminal::EndTransaction
(00E5B4F8) TTerminal::CopyToRemote
(000164B3) TCustomScpExplorerForm::ExecuteCopyMoveFileOperation
(0001734D) TCustomScpExplorerForm::ExecuteFileOperation
(00035A2C) TCustomScpExplorerForm::RemoteFileControlDragDropFileOperation
(00035BF7) TCustomScpExplorerForm::RemoteFileControlDDFileOperation
(00CBD2A0) TUnixDirView::PerformItemDragDropOperation
(00594FB7) Customdirview::TCustomDirView::DDProcessDropped
(005E5847) Dragdrop::TDragDrop::WndMethod
(0040C178) System::Classes::_18201
(000402B9) USER32.dll
(00036A55) USER32.dll
(0003538C) USER32.dll
(00034EAB) USER32.dll.DispatchMessageW
(00278B83) Vcl::Forms::TApplication::ProcessMessage
(00278BD3) Vcl::Forms::TApplication::HandleMessage
(00278F87) Vcl::Forms::TApplication::Run
(00147B33) Execute
(000038CB) wWinMain
(0101DD21) C6502_0
(00066C5C) ntdll.dll.RtlGetAppContainerNamedObjectPath
(00066C29) ntdll.dll.RtlGetAppContainerNamedObjectPath
(0102063D) C6633_3
(00E46685) TTerminal::CustomReadDirectory
(00147B33) Execute
(000038CB) wWinMain
(0101DD21) C6502_0
- Then this error:
Error
Out of memory
- I closed WinSCP. Above I mentioned that Ras Pi's power savings are disabled. I restarted Ras Pi to all it to 'reinitialize', then updated gamelists, then checked free space. used 17.75GB/25.89GB (free 8.14GB).
wellbeserious
Since you asked for session log, I didn't have it. So I redownloaded WinSCP emailed version and repeated exact steps. Updated trace file and session log sent to email. First file is session log. 39 compressed files, 528MB.
