Automating file transfer from local machine to Google Drive
dwaldrop
Indiana
I am new to WinSCP and am trying to find out if it is possible to automate moving 1 file from my local C: drive to a Google drive listed as D: on my machine. Hopefully this is not to vague.
Thanks in advance for any help.
Re: Automating file transfer from local machine to Google Drive
To automate file transfer between two local drives, you do not need WinSCP.
Use regular local file transfer automation commands, such as copy.
Good morning Martin,
As of right now I have a batch file using xcopy which I can place in the start menu or I can simply double click it to run it and it does copy the file to the Google drive. However, I am wanting it to run without me having to execute it. Any ideas would be great!
Thanks.
Well, that's not WinSCP question.
But in general, you can use Windows Task Scheduler.
