Mouse cursor while transferring via .NET
Denis
Leipzig
I am using WinSCP 5.21.8.0 via .NET. While the session to the (S)FTP-host is open and the file is transfered the mouse cursor appears (spinning wheel) and although the upload is running in a parallel thread this blocks other threads of the application.
Is there any parameter to avoid the mouse cursor?
Regards Denis.
Re: Mouse Cursor while transfering via .net
Is the mouse cursor the actual issue? Or is the cursor just a way how the Windows tells you that your code is blocking the GUI thread?
Denis x
the main problem is, that the GUI is blocked. Meanwhile I changed the code. Now I do not make the transfer with .NET but with a script file. This way it works.
Regards Denis.
