Receiving Reply 1004 to Command 4
connor.dawson
I'm using WinSCP 6.1.2.13797 command line to automate the process of backing up content from my Azure FTP server. I do this via a PowerShell script using the command:
& "C:\Program Files (x86)\WinSCP\WinSCP.com" `
    /log="$WinSCPLog" /loglevel=2 /logsize=6*1500M /ini=nul `
    /command `
    "option batch on" `
    "open ftps://<user>:<password>@<server>" `
    "cd /" `
    "lcd $CurrentMonthDirectory" `
    "synchronize local -delete -preservetime LogFiles LogFiles" `
    "synchronize local -delete -preservetime site site" `
    "synchronize local -delete -preservetime data data" `
    "exit"
I intermittently receive this response causing the WinSCP command to exit:
Got reply 1004 to command 4
Are there any suggestions to what may be causing this? Are there any ways to improve my script to account for this and continue the backup?
Thank you
Re: Receiving Reply 1004 to Command 4
connor.dawson
Hi Martin,
Our log generated by the process is about 5 GB total, 375 MB compressed. I took the tail end of the log and have attached it here.
Is there anything you're looking for specifically? Should I provide a different part of the log?
I does not look like the "Got reply 1004 to the command 4" is an error in the case. It is just a log entry.
What exactly did you mean when you wrote "receive this response"? Where/how did you receive it?
